Normal Topic Num lock on by default (Read 3854 times)
ruki
Oct 9th, 2023 at 4:10am
How can I have Num lock to be on by default?
Re: Num lock on by default
Reply #1 - Oct 9th, 2023 at 9:45am
You could simulate a numlock press:
if (!VirtualKeyboard.NumLocked)
	keyboard.SendKey(MindFusion.UI.Wpf.Key.NumLock);
or if you don't want to use numpad keys as arrows at all, use UnicodeKey instead of NumPadKey in custom layout.
ruki
Reply #2 - May 28th, 2024 at 6:47am
How to make caps locked on and remove the capbuttons and also make the UI reflect the caps lock is on. This works but doesn't reflect the UI.
            if (!VirtualKeyboard.CapsLocked)
                SendKey(MindFusion.UI.Wpf.Key.CapsLock);
Reply #3 - May 28th, 2024 at 7:27am
What do you mean by reflecting the UI? If you want keys to display only uppercase letters instead of default lower + upper case, you will have to apply a custom template as in:
https://mindfusion.eu/Forum/YaBB.pl?num=1478183033/1#1
