Normal Topic Alignment of nodes with the text inside (Read 922 times)
gaveen
Oct 11th, 2023 at 12:34am
I'm trying to align the selected nodes (in this example, align left). Although the nodes are aligned properly, the text inside moves out of the shape (Originally it is in center of the shape). How to keep the text inside the shape
Code (Javascript)
alignLeft(): void {
    const selectedNodes = this.diagram?.selection.nodes
    if (selectedNodes && selectedNodes.length > 0) {
      let leftmostX = selectedNodes[0].bounds.x
      let leftmostY = selectedNodes[0].bounds.y
      let nodeWidth = selectedNodes[0].bounds.width
      let nodeHeight = selectedNodes[0].bounds.height
      const verticalSpacing = 8
      for (let i = 1; i < selectedNodes.length; i++) {
        const node = selectedNodes[i]
        if (node.bounds.x < leftmostX) {
          leftmostX = node.bounds.x
          leftmostY = node.bounds.y
      for (let i = 0; i < selectedNodes.length; i++) {
        node.setBounds(new MindfusionDrawing.Rect(leftmostX, leftmostY, nodeWidth, nodeHeight), true)
        leftmostY += verticalSpacing
      this.diagram?.invalidate()
Re: Alignment of nodes with the text inside
Reply #1 - Oct 11th, 2023 at 8:14am
With what kind of nodes and texts is that happening? E.g. NodeLabels, attached nodes to contain text, standard node.text property? We can't see any problems trying that with ShapeNodes and their text property.
