Normal Topic How to delete item ? (Read 1034 times)
Mandy
Oct 26th, 2023 at 10:27am
Hi ,
I tried to remove the item in the editing window, but the item was not deleted.
What should I do?
private void Create_Click(object sender, RoutedEventArgs e)
            var item = new Appointment();
            item.Subject = "aaa";
            item.StartTime = new DateTime(2023, 10, 2);
            item.EndTime = new DateTime(2023, 10, 3);
            calendar.Schedule.Items.Add(item);
            appointment_id = item.Id;
            item.Recurrence = new Recurrence()
                Pattern = RecurrencePattern.Weekly,
                DaysOfWeek = DaysOfWeek.Monday,
                StartDate = item.StartTime,
                DailyRecurrence = DailyRecurrence.ByDayInterval,
                NumOccurrences = 3,
                RecurrenceEnd = RecurrenceEnd.NumOccurrences,
			item.Reminder = new Reminder()
				Type = ReminderType.Leading,
				TimeInterval = TimeSpan.FromMinutes(15)
            // Edit the clicked item
            var edititem = item.Recurrence.GetOccurrence(1);
            var editWindow = new EditWindow(calendar.Schedule);
            editWindow.SetAppointment(edititem);
            editWindow.Activate();
            editWindow.Show();
public partial class EditWindow : Window
        MindFusion.Scheduling.Schedule schedule { get; set; }
        MindFusion.Scheduling.Item item { get; set; }
        public EditWindow(MindFusion.Scheduling.Schedule schedule)
            InitializeComponent();
            this.schedule = schedule;
        public void SetAppointment(Item item)
            this.item = item;
        private void Remove_Click(object sender, RoutedEventArgs e)
            this.schedule.Items.Remove(this.item);
            //Dispatcher.InvokeAsync(() =>
            this.Close();
Re: How to delete item ?
Reply #1 - Oct 26th, 2023 at 3:38pm
Hi Mandy,
For recurrence instances you'll need to call recurrence.MarkException(item, true) instead of Items.Remove.
