Normal Topic How to receive keyboard event in myUserControl? (Read 879 times)
GrandSon
Nov 26th, 2023 at 3:50am
I implemented user-control(named MyControl) that have Label and RichTextBox.
And I set it ControlNode.Control.
MyControl want keyboard event (e.g. F2 key down).
I can handled KeyDown event where MyControl on the Form directly, but set MyControl to ControlNode.Control MyControl_KeyDown method wasn't called.
Below methods could't my problem.
DiagramView.Focus();
Diagram.Selection.AddItem(ControlNode);
DiagramView.Select();
MyControl.Focus();
Can MyControl on the ControlNode.Control receive Keyboard event directly?If can, how to reveive?
Now, I have passed event to MyControl when ControlNode received KeyDown event. Is there alternative (better) way?
I use MindFusion.Diagramming 7.0.0.
Re: How to receive keyboard event in myUserControl?
Reply #1 - Nov 26th, 2023 at 5:28pm
I've played a bit with focus:
1. The Focus() method doesn't seem to work from form's constructor nor Loaded event; e.g. you could print CanFocus value to verify. The earliest focus worked for me is form's OnShown event:
protected override void OnShown(EventArgs e)
	var control = new MyControl();
	var node = new ControlNode(diagramView, control);
	diagramView.Diagram.Nodes.Add(node);
	Debug.WriteLine(control.CanFocus);
	control.Focus();
2. Then actually the rich-text child control shows it has focus and keyboard events are received by it. So instead of control.KeyDown, handle richtext.KeyDown. If you prefer handling in user control, I've found it's possible to detect F2 in ProcessKeyPreview override:
public partial class MyControl : UserControl
	public MyControl()
		InitializeComponent();
	void richTextBox1_KeyDown(object sender, KeyEventArgs e)
		Debug.WriteLine("richTextBox1_KeyDown");
	const int WM_KEYDOWN = 0x100;
	const int WM_KEYUP = 0x101;
	protected override bool ProcessKeyPreview(ref Message m)
		if (m.Msg == WM_KEYDOWN && (Keys)m.WParam == Keys.F2)
			Debug.WriteLine("F2");
		return base.ProcessKeyPreview(ref m);
GrandSon
Reply #2 - Nov 27th, 2023 at 12:44am
Thanks slavcho.
I focused MyControl in DiagramView_Click, and I key pressed then I could get KeyDown event directly.
Reply #3 - Nov 27th, 2023 at 9:57am
I'm receiving direct MyControl_KeyDown events too if the rich-text is disabled. Do you need detecting F2 to enable the textbox and let users type?
So if that's the only situation when you need to handle keyboard event on the user control, I guess UserControl.KeyDown should work fine. If you need to detect keys while rich-text is active, you might have to go through ProcessKeyPreview or handle textbox' own events.
