Normal Topic Issues with Z-index when adding and removing elements. (Read 965 times)
nullable
Dec 4th, 2023 at 10:39am
Hello Mindfusion team. We have a plain virtualization method in out application that removes elements if they are out of view port bounds. This method is subscribed to diagram.UpdateLayout event. But after removing items and adding them Z-index is not correct for them. Please inspect attached video and demo app where I repeat this scenario with two text nodes.
nullable
Re: Issues with Z-index when adding and removing elements.
Reply #1 - Dec 4th, 2023 at 10:40am
Attached video
Reply #2 - Dec 4th, 2023 at 11:04am
Current version implements virtualization out of the box. If you prefer implementing your own, try assigning ZIndex property of items explicitly, or make sure they have same relative order in diagram.Items after readding.
nullable
Reply #3 - Dec 5th, 2023 at 6:51am
The solution is to use out of the box virtualization. The problem is displaying the trial shortcut. Should I re-create the license key to resolve this issue?
Reply #4 - Dec 5th, 2023 at 9:53am
Note that with a purchased license you get one year of maintenance (upgrades and support). If your company has extended it recently, make sure you are using the new license key you received with renewal.
