Normal Topic Diagram Links (Read 442 times)
PeteWhite
Diagram Links
Dec 28th, 2023 at 2:23pm
A couple of questions regarding DiagramLinks...
1. is there a way to add a custom shape (SVG) for the base, head and intermediate shapes?
2. is there a way to prevent the BaseShape, HeadShape, or IntermediateShape from rotating with the link?
Cheers,
Pete
Re: Diagram Links
Reply #1 - Dec 28th, 2023 at 4:34pm
1. You can set these only to Shape objects. If it's only the arrowhead geometry you need imported from SVG, try using the Shape.FromSvg result. If you need to show more elaborate SVG drawings, you could call SvgContent.Draw from DrawLink event handler.
2. There isn't out of the box. You could try drawing arrowheads yourself by calling DiagramLink.DrawArrowhead static method from DrawLink handler.
Set link's CustomDraw property to get DrawLink raised.
