Normal Topic Diagramming for Java Swing, V4.7.1 (Read 565 times)
Jan 30th, 2024 at 8:39am
We have released version 4.7.1 of JDiagram. It contains the following new features and improvements:
Drag-and-drop improvements
  • The control now displays a ghost image of nodes dragged from NodeListView. Set the DragIndicatorOpacity property to set the image opacity.
  • Set HorizontalDropAlignment and VerticalDropAlignment to specify placement of dropped node relative to mouse pointer
  • The Opacity property lets you create translucent DiagramItem by applying it to the alpha channel of all colors in the item.
  • TableNode copy constructor fixes.
  • Improved in-place editing of ItemLabels.
Distribution for the latest version can be downloaded here, or from the clients area on our site.
https://www.mindfusion.eu/JDiagramTrial.zip
Updated JAR is also available at the Maven Central Repository:
https://search.maven.org/artifact/eu.mindfusion/diagramming
