Normal Topic inconsistent export to PDF & SVG (Read 1592 times)
PeteWhite
Feb 7th, 2024 at 11:10am
I have been looking at the export features of the diagramming component, unfortunately there appears to be some inconsistencies with the output.
This is a screengrab...
firstly comparing this to the PDF version, the line styles don't appear to he been exported properly, there are no dashed lines, and the grid hasn't been exported.
The SVG has more problems... The node images bleed outside of the node shape, the link text is wrongly positioned, and some of the text is truncated, i.e. "Orifice" has been truncated to "Orific"
I've attached both the PDF and SVG exported files for your reference.
Cheers,
Pete
test_001.svg (Attachment deleted | 0 Downloads )
Re: inconsistent export to PDF & SVG
Reply #1 - Feb 7th, 2024 at 12:40pm
Could you please attach source diagram saved as XML file?
PeteWhite
Reply #2 - Feb 7th, 2024 at 3:25pm
Slavcho wrote on Feb 7th, 2024 at 12:40pm:
Hi Slavcho,
It's not the same diagram, but I've attached the XML file.
Edit: I figured out why the grid wasn't plotting with the PDF exporter, I needed to set PDFExporter.EnableGrid to true.
Cheers,
Pete
« Last Edit: Feb 7th, 2024 at 11:07pm by PeteWhite »
Reply #3 - Feb 8th, 2024 at 7:34am
Apparently PdfExporter does not support custom dash patterns at this time. As a work-around, you could export a copy of the diagram where they are replaced with standard dash or dot styles -
diagram.LoadFromXml("QSTest.xml");
var exportCopy = diagram.Clone();
foreach (var link in exportCopy.Links)
    if (link.Pen.DashPattern != null)
        link.Pen.DashStyle = DashStyle.Dash;
        link.Pen.DashPattern = null;
var pdfex = new PdfExporter();
pdfex.Export(exportCopy, "test.pdf");
PeteWhite
Reply #4 - Feb 8th, 2024 at 3:57pm
Thanks, did you manage to have a look at the issues with the SVGExporter?
Cheers,
Pete
Reply #5 - Feb 9th, 2024 at 6:58am
Our developer is looking into it.
Reply #6 - Feb 9th, 2024 at 11:18am
Try new build here for SVG texts -
https://mindfusion.eu/_beta/fcnet702.zip
