Normal Topic Customizing showAnchors behavior (Read 851 times)
Aman Shaikh
Feb 21st, 2024 at 12:25pm
Hey, I'm using mindfusion js api version: 3.5.7
I wanted to know if it's possible to show anchors on hover and selected. currently when I set it as "Auto", it shows up when I hover over the node but not when I select it. I tried setting `diagram.setShowAnchors(6 as any);` hoping bit manipulation would work and both Auto and Selected will be applied, but no luck.
Thanks in advance.
Re: Customizing showAnchors behavior
Reply #1 - Feb 21st, 2024 at 2:04pm
That's supposed to be supported; setting Auto | Selected shows them correctly in our .NET diagram libraries, but apparently we've never implemented it in JavaScript version. Our developers will try to fix that for upcoming release.
Reply #2 - Mar 7th, 2024 at 2:07pm
That's now supported by this build -
https://mindfusion.eu/_beta/jsdiag442.zip
diagram.showAnchors = ShowAnchors.Selected | ShowAnchors.Auto;
