Normal Topic How to get on increasing the clickable area of the playbutton on a node? (Read 1471 times)
Rama
Feb 28th, 2024 at 9:46am
Hi
I have my nodeListView, from there I am added a play button of type triangle with rotation of 90 (see pic)
Below is the current code implemented like this...
var node = diagram.getFactory().createShapeNode(bounds);
    node.locked = true;
    node.setShape("Triangle");
    node.setBrush('#000000');
    node.rotationAngle = 90;
    node.setBounds(bounds);
    node.fitInBounds = true;
    debugNodes.push(node);
The play button that I am using is supposed to be more clickable area than in (see pic.).
Something I need to place shape node in a canvas, so that when mouse moves, it should have more clickable area of the play button on a node (see pic clickable place).
please help me to share your thoughts how to achieve this.
Rama
Re: How to get on increasing the clickable area of the playbutton on a node?
Reply #1 - Feb 28th, 2024 at 10:39am
Some options are:
- keep the ShapeNode.shape property set to a rectangle or circle, and assign a png containing play icon to imageLocation. If you enable the transparent property, the shape won't be drawn, while you can control hit-test distance by setting node's bounds and / or imagePadding.
- replace ShapeNode.prototype.containsPoint(point) function with one that will accept the point from further away for the play-button node, and call the original function otherwise.
- create a custom Shape that defines the triangle as a smaller decoration, but otherwise the main outline is a large circle or rectangle. You can hide the main outline by setting brush to a transparent color, while it will still be used for hit-testing.
- replace the whole node group with a TableNode or CompositeNode. The table cell or composite's image component could be larger than the play icon for hit-testing, while displaying it centered.
Rama
Reply #2 - Feb 28th, 2024 at 3:51pm
Thank you Slavcho.
can you please help me to provide some pseudo code as per your suggestions.
Rama
Reply #3 - Feb 29th, 2024 at 6:48am
E.g. importing Thickness from @mindfusion/drawing:
var node = diagram.factory.createShapeNode(100, 100, 24, 24);
node.imageLocation = "play.png";
node.imageAlign = ImageAlign.Fit;
node.imagePadding = new Thickness(4, 4, 4, 4);
node.transparent = true;
node.shape = Shape.fromId("Ellipse");
Reply #4 - Feb 29th, 2024 at 6:52am
check tutorial 3 and SpanningCells examples, both showing how you can display multiple images and text labels in a single node.
Reply #5 - Feb 29th, 2024 at 7:14am
Custom hit-testing function:
var originalContainsPoint = ShapeNode.prototype.containsPoint;
ShapeNode.prototype.containsPoint = function (point)
	// e.g. replace this with an id, tag or shape check
	let isPlayButton = this.imageLocation == "play.png";
	if (isPlayButton)
		var hitTestRect = this.bounds.inflate(8);
		return hitTestRect.containsPoint(point);
	else
		return originalContainsPoint.apply(this, [point]);
