Normal Topic WPF Diagram.CreateImage not generating correct image (Read 1105 times)
Steve M
Feb 29th, 2024 at 7:42pm
I'm creating a very basic WPF Diagram with ShapeNode and DiagramLink. I use TreeLayout to arrange the nodes/links.
Everything looks great on screen, but CreateImage always creates an image that has all my Nodes on top of each other in in the top-left corner on the image that looks large enough to hold the correctly formatting tree.
Based on another post I found here, I tried adding this before the call to CreateImage, but it made no difference...
diagram.UpdateLayout();
diagram.Measure(diagram.Bounds.Size);
diagram.Arrange(diagram.Bounds);
I can try to extract all the relevant code into a small repro app, but I thought maybe I'm just missing something obvious since I'm pretty new to MindFusion.
One last thing... saving to an SVG with SvgExporter works fine.
Re: WPF Diagram.CreateImage not generating correct image
Reply #1 - Mar 1st, 2024 at 8:32am
Please try this build, without calling any layout functions -
https://mindfusion.eu/_beta/wpfdiag407.zip
Steve M2
Reply #2 - Mar 1st, 2024 at 6:44pm
It worked! Looks great. Thanks for the beta.
One semi-unrelated question... The image that is captured has padding on the top/left sides that matches my TreeLayout.Margins, but no padding on the bottom/right sides. The description for 'Margins' does only mention top-left, so this is probably by design. Any way to add padding to the bottom/right of the image? I can easily do it myself when saving the PNG, but was curious if there is a more correct way.
Thanks again for the help. I'm loving Mindfusion - very well thought out architecture.
PS: I had to create a new account to post this. My password manager didn't save my password and I don't seem to be getting any Reset Password emails from Mindfusion (yep, checked my spam folder as well).
Reply #3 - Mar 2nd, 2024 at 3:32pm
Exported image should be as large as diagram.Bounds. You could call ResizeToFitItems method before exporting to add margins around the tree -
diagram.Arrange(treeLayout);
diagram.ResizeToFitItems(margin);
var image = diagram.CreateImage();
Utilities.SaveImage(image, "test.png");
