Normal Topic about selfloop (Read 1946 times)
Nobu
about selfloop
Mar 7th, 2024 at 5:16am
Is it not possible to specify the start and end points of the self-loop?
Currently, when a self-loop is created, it is automatically created at the top of the node.
Also, the LinkShape is changed from Cascading to Bezier.
Re: about selfloop
Reply #1 - Mar 7th, 2024 at 6:31am
You can specify them from SetSelfLoopShape event handler -
void OnSetSelfLoopShape(object sender, LinkShapeEventArgs e)
	e.Handled = true;
	var link = e.Link;
	var r = link.Origin.Bounds;
	link.Shape = LinkShape.Cascading;
	var points = link.ControlPoints;
	points.Clear();
	points.Add(new PointF(r.X + 5, r.Y));
	points.Add(new PointF(r.X + 5, r.Y - 5));
	points.Add(new PointF(r.X - 5, r.Y - 5));
	points.Add(new PointF(r.X - 5, r.Y + 5));
	points.Add(new PointF(r.X, r.Y + 5));
	link.UpdateFromPoints();
Nobu
Re: about selfloop
Reply #2 - Mar 7th, 2024 at 8:24am
Thank you for your response.
When OnSetSelfLoopShape is reached, the ControlPoints of the Link is set to the Bezier value.
Is it possible to get the ControlPoints when the mouse is released?
Nobu
Re: about selfloop
Reply #3 - Mar 7th, 2024 at 8:37am
Sorry.
e.Handled = true
The above was missing.
I was able to achieve what I wanted.
Nobu
Nobu
Re: about selfloop
Reply #4 - Mar 8th, 2024 at 9:47am
In a self-transition, a link will pass through a node if it is implemented with the following properties.
Is it possible to make it go around the outside of the target node?
--Proterty
RouteLinks: True
LinkShape: Cascading
Re: about selfloop
Reply #5 - Mar 8th, 2024 at 11:35am
The sample code above places points around the node, have you left only the Handled assignment from it? AutoRoute does not apply to self-loops, so you'd just see the link as drawn by user if you don't assign to ControlPoints from that handler. If you want to specify only end points without other coordinates, you can still call the Route method:
	e.Handled = true;
	var link = e.Link;
	var p = link.StartPoint = e.Link.Origin.Bounds.Location;
	link.StartPoint = new PointF(p.X + 10, p.Y);
	link.EndPoint = new PointF(p.X + 20, p.Y);
	link.Route();
Nobu
Re: about selfloop
Reply #6 - Mar 8th, 2024 at 12:25pm
I was able to implement it based on your answer.
Regard,
Nodu
« Last Edit: Mar 8th, 2024 at 2:41pm by Nobu »
