Normal Topic Node and Group v.s. CompositeNode which is better? (Read 1116 times)
GrandSon
Mar 17th, 2024 at 9:12am
Hi, I want consists a complex UI. These have some parts.
e.g.
typeA has icon and input area.
typeB has icon and other parts like A and (other instance of)B.
If build B-1 includes A-1 and B-2 includes A-2.
User get bellow:
B-1
  A-1
  B-2
    A-2
I thought I can implement both way:
  • ComopositeNode(include EditComponent) and ShapeNode. And gorup using AttachTo method.
  • Define TypeAComposite. It has TextCompnent and EditComponent on a GridPanel.
How can I consider what is better using Group or Composite? (Group not suitable for complex layouts?)
or What is best way of complex UI layout?
Re: Node and Group v.s. CompositeNode which is better?
Reply #1 - Mar 18th, 2024 at 6:27am
CompositeNodes were added as more light-weight alternative to ControlNodes, but I guess they could replace groups in some situations too. E.g. ones where you'd add locked secondary nodes as decorations to a main node. CompositeNode would not work if you need individual objects from the group to be selectable and movable by users.
In any case, the less nodes you have in the diagram, the faster its user interaction and rendering are. So if your layouts can be implemented either way, try using CompositeNode for better performance.
If you need to display only icons and texts, you could also try TreeViewNode and TableNode classes.
GrandSon
Reply #2 - Mar 18th, 2024 at 6:56am
Thank you for replying.
This is an fascinating for me.
I'll try to implement using CompositeNode.
Reply #3 - Mar 18th, 2024 at 8:50am
Smiley Well, you shouldn't be seeing much difference unless you create thousands of nodes. If that's the case, also try the settings from StressTest example.
