Normal Topic Diagramming for WPF, V4.0.8 (Read 747 times)
Mar 26th, 2024 at 11:38am
Version 4.0.8 is a maintenance release containing several fixes and customer-requested features:
  • New LinkDensity partitioning method added to CompositeLayout, divides the graph depending on ratio of nodes to links in subgraphs.
  • AnnealLayout now normalizes distance calculations, making its cost property values independent from diagram's MeasureUnit.
  • Enable the FlipImage property of ShapeNode to make node's Image follow the geometric shape mirroring specified by FlipX and FlipY properties.
  • Set the AutoDeleteLinks property to false to prevent deleting links along with a node they connect, and disconnect the links instead.
Updated assemblies are also available as MindFusion.Diagramming.Wpf NuGet package.
