Normal Topic MindFusion.WinForms Pack, 2024.R1 (Read 1929 times)
May 2nd, 2024 at 7:25am
Version 2024.R1 is a maintenance release containing several fixes and customer-requested features:
.NET 8 support
The MindFusion.WinForms Pack distribution now includes assemblies and sample projects for .NET 8. Locally installed assemblies do not appear automatically in Visual Studio toolbox at this time; you can add the controls manually or through Nuget package manager.
MindFusion.Diagramming
Drag-and-drop improvements
  • DiagramView now displays a ghost image of nodes dragged from NodeListView. Set the DragIndicatorOpacity property to set the image opacity. Set DragIndicator to MouseCursor to revert to old behavior.
  • Set DropAlignment to specify placement of dropped node relative to mouse pointer.
  • Set the AutoDeleteLinks property to false to prevent deleting links along with a node they connect, and disconnect the links instead.
  • Fixed in-place edit for NodeLabels outside of node's boundaries.
  • Fixed repaint glitches of NodeLabels outside of node's boundaries.
  • New LinkDensity partitioning method added to CompositeLayout, divides the graph depending on ratio of nodes to links in subgraphs.
  • Fix for CellTextBrush not being serialized in JSON format.
  • Fixed flickering of view borders when BorderWidth is greater than 1.
  • Improved export of link texts by SvgExporter.
  • Nodes rendered inside NodeListView better match its MeasureUnit.
MindFusion.Spreadsheet
  • Formula bar preserves original text when evaluation is disabled.
  • Set the ShowLeadingApostrophes property to stop hiding escaping leading apostrophe (used to treat remaining cell content as text).
MindFusion.Charting
  • Fixed overflow error when drawing axis labels for large coordinates (moved from int to long type).
https://mindfusion.eu/WinFormsTrial.zip
Updated assemblies are also available as https://www.nuget.org/packages/MindFusion.Pack.WinForms/ NuGet package.
