Normal Topic Diagramming for JavaScript, V4.4.3 (Read 586 times)
May 16th, 2024 at 1:40pm
Version 4.4.3 is a maintenance release containing several fixes and customer-requested features:
  • Due to problems with some script loaders, the library no longer registers web components automatically. Call the WebComponents.register method to explicitly register component classes.
  • Set cornerRadius to change the size of corners when node's shape is set to a rounded rectangle.
  • Set the autoDeleteLinks property to false to prevent deleting links along with a node they connect, and disconnect the links instead.
  • Fixed a bug where child nodes keep reference to their deleted container.
https://mindfusion.eu/JsDiagram.zip
Updated scripts are also available as @mindfusion/diagramming NPM package.
« Last Edit: May 17th, 2024 at 9:41am by Forum Admin »
