Normal Topic How to delete Component in a CompositeNode use by Delete key press. (Read 1057 times)
GrandSon
May 20th, 2024 at 8:24am
I want remove selected* Component(extends ComponentBase) in a CompositeNode.
(*MyClass has IsSelected original property)
I implemements DiagramView.MouseDown event handler like below:
Code (C++)
private void DiagramView_KeyDown(object? sender, KeyEventArgs e)
    if(!Keys.Delete.Equals(e.KeyData))
        return;
    foreach(var child in Children)
        if(child.IsSelected)
            Delete(child);
It is worked, but parent CompositeNode is deleted too.
I need extends DiagramView and override ProcessCmdKey to achive this?
Re: How to delete Component in a CompositeNode use by Delete key press.
Reply #1 - May 20th, 2024 at 8:54am
If you don't need to delete diagram items using Del key at all, set DiagramView.DelKeyAction = None. If you need to prevent it selectively, handle the NodeDeleting validation event and set args.Cancel. E.g. args.Cancel = args.Node is CompositeNode && node contains selected components;
GrandSon
Reply #2 - May 21st, 2024 at 5:11am
Thank you so much.
I got it.
I'll use NodeDeleted event.
Reply #3 - May 21st, 2024 at 6:50am
you mean NodeDeleting Wink
