Normal Topic Differences in node selection states (Read 764 times)
koichi_satoh
Jul 8th, 2024 at 6:29am
When multiple nodes are selected, there are two selection states, as shown in the attached image.
In the image below, Label1 has white handles.
In the image below, Label2 has gray handles.
Is it possible to eliminate this difference?
Also, is it possible to programmatically distinguish the difference between these two selection states?
Re: Differences in node selection states
Reply #1 - Jul 8th, 2024 at 8:39am
White handles are for diagram.ActiveItem. This can be useful to distinguish one of the nodes in the selection as alignment target, or for application commands such as make same size / color / etc. You can change the handle brushes by setting properties of diagram.ActiveItemHandlesStyle and diagram.SelectedItemHandlesStyle.
koichi_satoh
Reply #2 - Jul 8th, 2024 at 11:13am
Understood. Thank you very much.
