Normal Topic Diagramming for WPF, V4.1.2 (Read 832 times)
Aug 30th, 2024 at 7:54am
We have released version 4.1.2 of WPF Diagramming library. It contains the following new features and improvements:
  • DividerPen property added to ContainerNode, TableNode and TreeViewNode classes. It lets you customize the appearance of the divider line drawn between a node's caption bar and content area.
  • PatternRouter no longer ignores containers whose Obstacle property is enabled.
  • Unfolding a ContainerNode now always restores original size from UnfoldedSize property, regardless of AutoGrow and AutoShrink values. To revert to old behavior, call ResizeToFitChildren from ContainerUnfolded event handler.
  • Fixed rendering of RoundedLinks with larger StrokeThickness.
  • Fix for tooltips not closing when the mouse pointer moves outside of the DiagramView.
  • Minimum required .NET Framework version lowered from 4.7.2 to 4.6.2.
Updated assemblies are also available as MindFusion.Diagramming.Wpf NuGet package.
