Normal Topic Force @ regardless if UK or US keyboard selected in windows (Read 1104 times)
ruki
Sep 12th, 2024 at 6:38am
I noticed that if the UK keyboard is selected, the @ symbol above the 2 key turns into " .
We also have a dedicated @ key but it simulates a SHIFT 2 which ofcourse results in " entered into the textbox.
How can I force the @ to be @ reglardless of UK or US keyboard? Even if it just for the dedicated key, although ideally both on both keys.
Or is there a way to force the Mindfusion to be US keyboard regardless of the windows selected keyboard? I can't change the keyboard system wide as the app will be running in an account that is locked down.
Re: Force @ regardless if UK or US keyboard selected in windows
Reply #1 - Sep 12th, 2024 at 10:47am
RegularKey always sends its virtual key code translated through current language table, unless you set the Content property. For the dedicated @ key, you can set RegularKey.Content property to "@", or replace the key with UnicodeKey instance, instead of using Shift+2 ExtendedKey sequence.
If the keyboard is only used internally for your application, you could handle the WM_INPUTLANGCHANGEREQUEST Windows message to prevent language changes (but then UK users wouldn't be able to type their pound character).
ruki
Reply #2 - Sep 16th, 2024 at 1:17am
I have specified as
    <Key xsi:type="UnicodeKey">
      <Left>73.346153846153982</Left>
      <Top>186</Top>
      <Width>60</Width>
      <Height>40</Height>
      <Character>64</Character>
      <Repeat>1</Repeat>
    </Key>
In the keyboard creator when I do a test, the @ is entered as expected.
However in my WPF application no character is entered when I press this key.
I am initializing as below:
            AutoReleaseModifierKeys = true;
            AutoFill = true;
            TemplateLayout = KeyboardLayout.Create(Assembly.GetExecutingAssembly().GetManifestResourceStream(
"XXXX.resources.vkb_general_template.xml"));
            AutoRepeat = false;
            AutoUpdateCulture = false;
            IsStandAlone = false;
ruki
Reply #3 - Sep 16th, 2024 at 1:35am
I'm using 5.0.4 nuget version of MindFusion.Keyboard.Wpf
ruki
Reply #4 - Sep 16th, 2024 at 2:14am
Ok I found the issue. If you make the virtualkeyboard "collapsed" by default in WPF XAML the unicodekey do not work.
Reply #5 - Sep 16th, 2024 at 11:02am
UnicodeKey seems to work after un-collapsing in our test project attached here. Please let us know what we should change to reproduce that.
ruki
Reply #6 - Oct 1st, 2024 at 2:48am
Strange. The project basically had a global keyboard and a ContentPresenter control where the views were injected into. The keyboard was collapsed at launch and then sometime later during the application and keyboard was made visible and the unicode keys didn't work. However now I make the keybaord visible and then collapse at launch and seems to work. I tested this multiple times so I am confident it was related we now no longer have the issue with the workaround.
May I suggest collapsing the keyboard in XAML, and then maybe in a button press making the keyboard visible and then see if the unicode characters are working?
Reply #7 - Oct 1st, 2024 at 6:00am
That's what our test project above does:
<vkb:VirtualKeyboard ...Visibility="Collapsed" />
Do you mean that ContentPresenter is initially collapsed, and you are adding the keyboard to it dynamically?
