Normal Topic Custom anchor point between DiagramNode and DiagramLink (Read 317 times)
Kamil
Oct 3rd, 2024 at 10:41am
In my code, I'm automatically creating a destination node if a link doesn't have a destination node. I'm using linkCreated event for that:
Code (Javascript)
export const handleLinkCreated = (diagram, args) => {
    const link = args._link;
    const destination = args._destination;
    link.text = DEFAULT_LINK_TEXT;
    link.brush = ARROW_HEAD_COLOR;
    link.zIndex = LINK_ZINDEX;
    if(!destination) {
        const linkTargetPoint = link.points.at(-1);
        const destinationNode = diagram.factory.createShapeNode(linkTargetPoint._x, linkTargetPoint._y, MOCK_RECTANGLE_UNIT.size, MOCK_RECTANGLE_UNIT.size);
        destinationNode.allowOutgoingLinks = false;
        const anchorPatternTargetNode = new mfDiagramming.AnchorPattern([
            new mfDiagramming.AnchorPoint(MOCK_RECTANGLE_UNIT.inPortPosition.x, MOCK_RECTANGLE_UNIT.inPortPosition.y, true, false, mfDiagramming.MarkStyle.Custom, ANCHOR_POINT_COLOR, ANCHOR_POINT_SIZE),
        destinationNode.addLabel(DEFAULT_UNIT_TEXT).setCenterPosition(0, -MOCK_RECTANGLE_UNIT.size / 2 - 2);
        destinationNode.anchorPattern = anchorPatternTargetNode;
        link.setDestination(destinationNode);
    link.route();
and here is my implementation of the function that renders a custom anchor point:
Code (Javascript)
export const handleDrawAnchorPoint = (_sender, e) => {
    const p = e.location;
    const ctx = e.context;
    const CIRCLE_RADIUS = 0.5;
    const STROKE_WIDTH = 0.5;
    const OFFSET = 0.5;
    ctx.beginPath();
    ctx.fillStyle = 'rgb(0,0,0)';
    ctx.strokeStyle = 'rgb(255,255,255)';
    ctx.lineWidth = STROKE_WIDTH;
    ctx.ellipse(p.x - CIRCLE_RADIUS + OFFSET, p.y - CIRCLE_RADIUS + OFFSET, CIRCLE_RADIUS * 2, CIRCLE_RADIUS * 2, Math.PI / 4, 0, 2 * Math.PI);
    ctx.fill();
    ctx.stroke();
The problem is that my anchor point in being drawn on top of the link. I want it to be between the destination node and the link (the link should be on top).
The attachment contains my current result.
Could you advise me on how to achieve that?
Re: Custom anchor point between DiagramNode and DiagramLink
Reply #1 - Oct 3rd, 2024 at 11:49am
What is the LINK_ZINDEX value? Anchor points are drawn along with their node, and link will draw on top if its zIndex value is large than node.zIndex. That's auto-assigned when you create the new node, so try setting link.zIndex = destinationNode.zIndex + 1.
Kamil
Reply #2 - Oct 4th, 2024 at 7:15am
LINK_ZINDEX value is 1000. I've also added a line for setting zIndex for destination node:
Code (Javascript)
    if(!destination) {
        destinationNode.zIndex = 0;
But nothing changed.
Reply #3 - Oct 4th, 2024 at 1:34pm
Right, the diagram sets anchor points as topmost actually. For time being try replacing this method in node prototype:
var originalAddAP = DiagramNode.prototype.addAnchorPointVisuals;
DiagramNode.prototype.addAnchorPointVisuals = function()
	originalAddAP.apply(this);
	this.anchorPatternVisual.zIndex = this.zIndex + 0.1;
Kamil
Reply #4 - Oct 7th, 2024 at 9:14am
Thanks for the solution Smiley Now it works perfectly!
