Normal Topic Issue with DiagramView alignment within Ruler. (Read 655 times)
nullable
Oct 14th, 2024 at 12:30pm
Please refer to the projects that I've attached in the previous topic, as I also have some issues with scroll and ruler alignment. Before the update Diagram was aligned at the center by default, with the scroll bar being attached to the right side of the ruler and coordinates of the ruler were bound to the diagram.
But in the latest version if I use DiagramView, it is aligned to the left, and if I change the alignment to center, the ruler coordinates will not synchronize, and the scroll bar will be attached to the diagram directly, not to the right side of the ruler.
Could you please tell me, how to get the same alignment as it was before the last version?
Re: Issue with DiagramView alignment within Ruler.
Reply #1 - Oct 15th, 2024 at 10:45am
Ruler sets hosted view's HorizontalAlignment and VerticalAlignment to Stretch internally, and we haven't really considered situations where you'd be changing them to Center. We'll review these for next release. Difference from previous version is placing a ScrollViewer (also stretch-aligned) between itself and the Diagram instance, and that ScrollViewer apparently centering the diagram by default.
nullable
Reply #2 - Oct 16th, 2024 at 6:26am
It would be also nice to know ETA of your next release.
Reply #3 - Oct 21st, 2024 at 5:51am
This build lets you center the diagram within diagram view by setting HorizontalContentAlignment:
https://www.nuget.org/packages/MindFusion.Diagramming.Wpf/4.1.4-rc2
<mindfusion:Ruler
    HorizontalAlignment="Stretch"
    VerticalAlignment="Stretch">
    <mindfusion:DiagramView x:Name="DiagramView"
        HorizontalContentAlignment="Center" />
</mindfusion:Ruler>
nullable
Reply #4 - Oct 22nd, 2024 at 11:51am
Yeah, it works as expected. Thank you!
nullable
Reply #5 - Nov 26th, 2024 at 10:18am
I would also like to ask if there is something we can do about the coordinates display. In the attached app I set width of 1000 units to diagram, but ruler display 600 by X-axis coordinate. Can I synchronize this ruler with the diagram?
Reply #6 - Nov 26th, 2024 at 1:10pm
Try changing ruler's Unit:
<mindfusion:Ruler Unit="WpfPoint" ...
and I can't actually see this project changing diagram's width, so the diagram has default A4 size. You can change diagram's width by setting Bounds:
diagram.Nodes.Add(imageNode);
diagram.Nodes.Last().Move(random.Next(Bottom, Top), random.Next(Bottom, Top));
Debug.WriteLine(diagram.Bounds);
diagram.Bounds = new Rect(Bottom, Bottom, Top, Top);
nullable
Reply #7 - Nov 26th, 2024 at 1:50pm
That worked, thank you!
