Normal Topic RenderTransform does not work on SvgNode. (Read 1544 times)
nullable
Oct 22nd, 2024 at 11:06am
Hello, MindFusion Team!
It seems that in version 4.0, setting the RenderTransform property on an SvgNode does not affect the rendering of the element. In the previous version, I could change the position, rotation, and scale of the SvgNode using this property, and I would like to see this in the new version as well.
Re: RenderTransform does not work on SvgNode.
Reply #1 - Oct 23rd, 2024 at 10:56am
Could you post a sample transform of yours? We are not sure if it will work the same as in v3 if we just bind new item-view's RenderTransform to the node's RenderTransform. We might have to add a new property for a more- local transform instead.
nullable
Reply #2 - Oct 24th, 2024 at 4:20am
Here I use RenderTransform to apply rotation and scale to my SvgNode
Reply #3 - Oct 24th, 2024 at 1:54pm
imageNode doesn't show at all if we downgrade this project to v3.9.5, unless also commenting out the imageNode.RenderTransform = matrixTransform assignment.
Anyway we aren't sure we can directly bind to RenderTransform from our new separate item presenters now, and also plan to remove the FrameworkElement base of DiagramItem (v5 when we also remove support for standalone Diagram control), so RenderTransform would disappear then. We'll try to add DiagramItem's own Transform property instead; hopefully it will work for your scenario.
Reply #4 - Oct 24th, 2024 at 4:11pm
Please check if the new DiagramItem.Transform property here works for you -
https://www.nuget.org/packages/MindFusion.Diagramming.Wpf/4.1.4-rc4
Since we couldn't see the RenderTransform-ed node with v3 in the test project, we aren't sure if Transform works exactly the same - locality could be different, where the new transform is applied relative to the node-presenter visual created by DiagramView. Anyway if you need to apply some transient transforms or animations, it shouldn't be much trouble to adapt to item-relative ones.
nullable
Reply #5 - Oct 25th, 2024 at 1:09pm
Here in this demo I use RenderTransform to reflect node horizontally/vertically. I found out that in newer version vertical reflection does not seem to work (if using Transform property)
Reply #6 - Oct 28th, 2024 at 11:15am
Reflection itself works from what we can see (project with v4 diagram attached), but transform locality is different from RenderTransform. You no longer have to translate by node's origin:
private void ReflectHorizontally(object sender, RoutedEventArgs e)
    var matrixTransform = new MatrixTransform();
    var trs = CreateTRSMatrix(new Vector2(0, 0), rotation: 0, new Vector2(-1, 1));
    matrixTransform.Matrix = new Matrix(trs.M11, trs.M12, trs.M21, trs.M22, trs.M31, trs.M32);
    var imageNode = diagram.Nodes.First();
    imageNode.Transform = matrixTransform;
private void ReflectVertically(object sender, RoutedEventArgs e)
    var trs = CreateTRSMatrix(new Vector2(0, 0), rotation: 0, new Vector2(1, -1));
nullable
Reply #7 - Dec 13th, 2024 at 10:26am
It seems like Transform property is not reliably working when setting DevFlags.LightweightPresenters to true;
Reply #8 - Dec 16th, 2024 at 8:17am
Transform + LightweightPresenters should work with new build here -
https://www.nuget.org/packages/MindFusion.Diagramming.Wpf/4.1.5-rc2
nullable
Reply #9 - Dec 16th, 2024 at 9:08am
Yeah, it works on the new build, thank you!
