Normal Topic Adjustable ToolTip Vertical Line (Read 2093 times)
Cajunman64
Oct 22nd, 2024 at 3:09pm
The are two objects I am trying to implement into my RealTimeChart LineChart.
First is to get the ToolTip to display the Pressure and time when my mouse pointer is hovered over the line.
I managed to enabled the Tooltip function in the Properties of the Chart but I haven't figured out how to add the code to my form.
Using the example from "Re: Display X and Y value when hovering on points of line on" I had added the code under "class YTooltip : Series" but the upper part of the Code I do not know how to add it to my Form....Attached is my form Code.
Second is I like to add Two "Adjustable ToolTip Vertical Line" where the user can move to two different places of the Line Chart where I can write a code to calculate the differential pressure between the two points. like in photo
Re: Adjustable ToolTip Vertical Line
Reply #1 - Oct 23rd, 2024 at 12:00pm
The Pressure series class from attached code overrides GetLabel to return Sample.Label for LabelKinds.ToolTip - does that tooltip appear when the mouse pointer hovers over a point? Instead of the Sample.Label property value, you could return concatenated Sample.Value and Sample.Time from GetLabel.
One way to draw those lines is by passing their coordinates to a custom SeriesRenderer object added to the plot:
class MarkerLineRenderer : Renderer2D
	public MarkerLineRenderer(SimpleSeries series) :
		base(new ObservableCollection<Series> { series })
	protected override void Draw(RenderContext context)
		var series = Series[0];
		for (int i = 0; i < series.Size; i++)
			double x = series.GetValue(i, 0);
			var point = GetPixel(x, context.XAxis, 0, context.YAxis, context.Component);
			context.Graphics.DrawLine(
				Pens.Red, point.X, 0, point.X, (float)context.Component.ActualHeight);
var markerCoords = new SimpleSeries(
	new double[] { 5, 20 }, null);
lineChart.Plot.SeriesRenderers.Add(
	new MarkerLineRenderer(markerCoords));
the coordinates being relative to the chart's X axis range. You could get the values from e.g. TrackBar controls, or possibly implement a custom PlotController class to let users draw the range interactively inside the plot.
Cajunman64
Reply #2 - Oct 23rd, 2024 at 4:16pm
I had added the "class MarkerLineRenderer : Renderer2D" code but not sure where to add the lower part of the code...when I add the whole code I get errors....Code 1.png
Thanks for the help
Reply #3 - Oct 23rd, 2024 at 4:29pm
You should be able to call those few lines from MainForm constructor, after the other lineChart... assignments.
Reply #4 - Oct 24th, 2024 at 1:36pm
Re tooltips, when it shows that highlight for current point from your last screenshot, it should also render the GetLabel result. I guess make sure the Sample.Label values returned by GetLabel aren't empty strings.
