Normal Topic Unable to Add/Edit text in BPMN Diagram (Read 227 times)
Avinash
Nov 12th, 2024 at 11:12am
When i drap and drop text into the canvas, I am unable to edit text on Double click on it, I can only able to move text!! I have experiencing same even in Demos:- BPMN Diagram.
Re: Unable to Add/Edit text in BPMN Diagram
Reply #1 - Nov 12th, 2024 at 12:53pm
Try setting the DiagramView.allowInplaceEdit property.
Avinash
Reply #2 - Nov 13th, 2024 at 5:45am
I have set allowInplaceEdit = true, and i can able to log event on doubleclick also, but still am unable to edit inplace. Is there anything else i have to check for?
this.diagram.allowInplaceEdit = true;
Thanks in advance
Regards
Avinash
Reply #3 - Nov 13th, 2024 at 5:58am
That's a property of DiagramView and not Diagram. Older sample code might be showing it set on Diagram, but that's from the time before we introduced separate view class. Try setting this instead:
this.diagramView.allowInplaceEdit = true;
p.s. now I can see we have omitted moving that property to DiagramView in BPMN example code you were referring to.
Avinash
Reply #4 - Nov 13th, 2024 at 6:03am
Thank You Slavcho,
Its working Smiley
Avinash
