Normal Topic Can i create Custom JSON and render in BPMN Diagram? (Read 550 times)
Avinash
Nov 13th, 2024 at 8:42am
When i create a simple Diagram and generate JSON of it, It seems pretty large. Which i cannot create that kind of JSON to render it back.
I have some data with links between them, From that data i want to create a simple JSON and render in BPMN Diagram.
Thanks in advance.
Re: Can i create Custom JSON and render in BPMN Diagram?
Reply #1 - Nov 13th, 2024 at 10:08am
The diagram has toJson and fromJson methods you could call. If you mean their result is too large, you could devise a simple format and load from it as shown in tutorial:
https://www.mindfusion.eu/onlinehelp/jsdiagram/CC_Tutorial_1__Loading_Graph_Data...
Saving could be done by looping over the diagram's nodes and links, creating corresponding node or link objects in same format, and calling JSON.stringify. Let me know if you need sample code for that.
Avinash
Reply #2 - Nov 13th, 2024 at 10:34am
Thank You Slavcho,
I'll go through
Avinash
