Normal Topic ToolTips bindings to items not working (Read 163 times)
nullable
Dec 6th, 2024 at 11:51am
Hello MindFusion team!
I use custom tooltip data in my application. I mentioned that after 4.0 version diagram items styles are still applied, but data context property is not being retrieved for the tooltip. I've attached these two projects to show how it works. Question is, how can I bind to DiagramItem in newer version?
Re: ToolTips bindings to items not working
Reply #1 - Dec 9th, 2024 at 6:54am
Hi there,
<ToolTip x:Key="ItemToolTip"
        DataContext="{Binding Path=PlacementTarget, RelativeSource={x:Static RelativeSource.Self}}">
    <TextBlock Text="{Binding CustomData}"/>
</ToolTip>
Relying on PlacementTarget being a diagram item will not work anymore with v4's presenter-based implementation. New diagram build here sets DataContext automatically to the item -
https://www.nuget.org/packages/MindFusion.Diagramming.Wpf/4.1.4
so this Xaml should be enough now -
<ToolTip x:Key="ItemToolTip">
</ToolTip>
nullable
Reply #2 - Dec 12th, 2024 at 6:35am
This solution worked for me, thank you!
