Hot Topic (More than 10 Replies) In My Javascript diagramming, Am unable to set Undo/Redo functionality. (Read 1112 times)
Avinash
Jan 3rd, 2025 at 5:52am
Am using javascript Diagramming in Angular 13 application, I have integrated undo/Redo functions with function but it not working but in logs prints as "No actions to undo."  Here are my functions am i doing anything wrong !!
initializeDiagram() {
    const element = document.getElementById('diagram');
    if (element instanceof HTMLCanvasElement) {
      this.diagramView = DiagramView.create(element);
    } else {
      console.error("Element with ID 'diagram' is not a canvas or does not exist.");
      return;
    // DiagramView Configuration
    this.diagramView.licenseKey = this.licenseKey;
    this.diagramView.allowInplaceEdit = true;
    this.diagramView.routeLinks = true;
    this.diagramView.showGrid = true;
    this.diagramView.allowUndo = true;
    this.diagramView.behavior = Diagramming.Behavior.Modify;
    this.diagramView.behavior = Diagramming.Behavior.DrawLinks;
    // Initialize Diagram
    this.diagram = this.diagramView.diagram;
    this.diagram.width = 1300;
    this.diagram.height = 600;
    // Enable UndoManager
    if (this.diagram.undoManager) {
      this.diagram.undoManager.enabled = true;
      this.diagram.undoManager.maxUndoLevels = 50; // Optional
      console.log("UndoManager enabled");
    } else {
      console.error("UndoManager is not available in the diagram object.");
    // Debugging: Log UndoManager state after operations
    this.diagram.addEventListener(Events.nodeCreated, () => this.logUndoRedoState());
    this.diagram.addEventListener(Events.nodeModified, () => this.logUndoRedoState());
    this.diagram.addEventListener(Events.nodeDeleted, () => this.logUndoRedoState());
    this.diagram.addEventListener(Events.linkCreated, () => this.logUndoRedoState());
    this.diagram.addEventListener(Events.linkDeleted, () => this.logUndoRedoState());
    // Initialize Undo/Redo Buttons
    this.initializeUndoRedoButtons();
    // Attach zoom and other controls
    this.initializeZoomControls();
initializeUndoRedoButtons() {
    const undoButton = document.getElementById("undoButton");
    const redoButton = document.getElementById("redoButton");
    if (undoButton) {
      undoButton.addEventListener("click", () => {
        if (this.diagram.undoManager?.canUndo()) {
          this.diagram.undoManager.undo();
          console.log("Undo performed.");
        } else {
          console.warn("No actions to undo.");
    if (redoButton) {
      redoButton.addEventListener("click", () => {
        if (this.diagram.undoManager?.canRedo()) {
          this.diagram.undoManager.redo();
          console.log("Redo performed.");
        } else {
          console.warn("No actions to redo.");
Re: In My Javascript diagramming, Am unable to set Undo/Redo functionality.
Reply #1 - Jan 3rd, 2025 at 7:26am
I don't think there's DiagramView.allowUndo property in the API. Try setting Diagram.undoEnabled instead:
https://www.mindfusion.eu/onlinehelp/jsdiagram/P_MindFusion_Diagramming_Diagram_...
Avinash
Reply #2 - Jan 3rd, 2025 at 7:53am
Hi Slavcho,
Even i have tried this.diagramView.undoEnabled = true;, But still its not working, is there any alternative or Method i can try?
Reply #3 - Jan 3rd, 2025 at 7:55am
Hi Avinash,
It's a property of the Diagram object. Try setting this.diagram.undoEnabled = true;
Avinash
Reply #4 - Jan 3rd, 2025 at 8:09am
Thank you, Its working only for the nodes created, Undo will not work for links created and text added inside nodes?
Reply #5 - Jan 3rd, 2025 at 8:45am
Undoing interactively drawn links seems to work in my test. In what way are you creating them?
Avinash
Reply #6 - Jan 3rd, 2025 at 9:28am
Yes links Undo/Redo is working at my end too, Is it possible to undo text inside nodes??
Reply #7 - Jan 3rd, 2025 at 1:47pm
New scripts here should undo inplace-edited texts -
https://mindfusion.eu/_beta/jsdiag451.zip
Avinash
Reply #8 - Jan 6th, 2025 at 7:32am
Thank you Slavcho, I'll check it out and let know if its working.
Avinash
Reply #9 - Jan 7th, 2025 at 5:21am
Hi Slavcho,  Am confused going through the scripts you have share, can you please guide me where should i place this script. I got jsdiag451 folder after downloading, should i have to place in my node_modules or somewhere!! can you please help me out.
Thanks in advance
Reply #10 - Jan 7th, 2025 at 8:50am
Here's the diagramming package in node_modules format, you can overwrite the folder under node_modules/@mindfusion:
https://mindfusion.eu/_beta/modules_451.zip
Assuming the other dependent packages there (common, graphs, etc) are from v4.5 of the diagram.
Avinash
Reply #11 - Jan 7th, 2025 at 9:10am
Thank you Slavcho, its's Working  Smiley
