Normal Topic Caching zoom and visible area for every page in TabbedDiagramView (Read 216 times)
Kamil
Jan 3rd, 2025 at 12:07pm
In our React application we use TabbedDiagramView. Mindfusion allows to perform scroll and zoom on every page of our tabbed diagram. However, whenever I zoom/scroll the first page, all the other pages are zoomed/scrolled as well. I would like to avoid that and make every page to remember its own zoom and visible area. Could you advise me on how to achieve that?
Online
Re: Caching zoom and visible area for every page in TabbedDiagramView
Reply #1 - Jan 6th, 2025 at 11:43am
New scripts here keep separate zoom and scroll per diagram view tab -
https://mindfusion.eu/_beta/jsdiag451.zip
Kamil
Reply #2 - Jan 7th, 2025 at 10:47am
Thank you for the file. Could you describe where exactly the implementation is located in these files?
In our project we are importing mindfusion via npm. Will these changes be available in npm in the future?
Online
Reply #3 - Jan 7th, 2025 at 11:26am
We should release this week. Meanwhile you could try module scripts from https://mindfusion.eu/Forum/YaBB.pl?num=1735883537/10#10
Kamil
Reply #4 - Jan 8th, 2025 at 9:55am
Thank you for the clarification. I will try it out.
Tooni
Reply #5 - Jan 10th, 2025 at 2:55pm
Is there a way to control the zoomFactor for each page of a TabbedDiagramView programmatically?
Online
Reply #6 - Jan 13th, 2025 at 7:35am
Hi Toni,
When changing tabs, TabbedDiagramView happens to save / restore zoom level using DiagramPage.zoomFactor field. That's not published in TypeScript definitions at this time, you'd need to set it using (view as any) syntax or declare it in extension interface.
