Normal Topic Borders are not correcto at preview (Read 38 times)
Alvaro68
Jan 10th, 2025 at 10:26pm
I am using "Report" to design a labels printing reporton letter size paper; there is a "DataRange" with location 8mm, 9mm but in "ReportViewer" borders are not correct. How can I fix it? see atached images.
Re: Borders are not correcto at preview
Reply #1 - yesterday at 12:44pm
Note the Margins(15) assignment in MainForm class of that example. You could set margins to non-uniform horizontal and vertical values as well, or set zero ones. Generally report coordinates are relative to the printable area of a page, and there are non-printable margins you could change via printer's settings. The on-screen ReportViewer control just simulates these margins with whatever property size you set.
Alvaro68
Reply #2 - yesterday at 5:31pm
I was able to make it work but only on first page.
The first page is correct, however, from the second page onwards they are not correct. See attached file.
How can I make all pages start printing at same margins?
Thanks in advance.
