Normal Topic SvgNode.Image rendering issue. (Read 75 times)
nullable
Jan 14th, 2025 at 9:46am
Hello MindFusion team!
In the app I add the following image to SvgNode. If you open it with Paint 3D you will see that there is a line on its right side. But in the app this line is not rendered by the node. Maybe there is something I can do to make these images match?
Re: SvgNode.Image rendering issue.
Reply #1 - Jan 14th, 2025 at 2:51pm
That line seems to consist of transparent pixels, and since your diagram background is white, it blends with the non-transparent white pixels from the bitmap. Changing the background seems to show the line correctly, as in attached image.
