Normal Topic Link display inconsistencies between diagram and SVG (Read 141 times)
nullable
Jan 21st, 2025 at 1:48pm
Hello, MindFusion Team!
I tried exporting line with the specific StrokeDashStyle to SVG and mentioned that it does not look the same as it displays in diagram in the app. Please check the attached project and images. You can clearly see, that dots look thicker in SVG file. Is there a workaround I can use to miss that discrepancy?
Re: Link display inconsistencies between diagram and SVG
Reply #1 - Jan 22nd, 2025 at 9:12am
Our developer will investigate; we suspect SVG adds caps to the dashes (e.g. square instead of flat).
Reply #2 - Jan 24th, 2025 at 12:32pm
Try new build here -
https://www.nuget.org/packages/MindFusion.Diagramming.Wpf/4.1.6-beta2
nullable
Reply #3 - Jan 27th, 2025 at 5:42am
Thank you, now size of line segments is the same between svg and the diagram. Now I only see some sort of offset that covers line head in the SVG. Please compare these two pictures, in the diagram the arrow head is clearly seen, whereas in the SVG file it is overlapped by  the line. Judging by the start of this digram link you might guess that some sort of offset is applying when exporting to SVG.
nullable
Reply #4 - Jan 27th, 2025 at 5:43am
I also attach SVG here
Reply #5 - Jan 27th, 2025 at 1:09pm
If you look at top-left without scrolling, problem seems dashes starting from a different place (half of first dash missing in WPF), and so also not ending at same place of the dash array. Maybe there's some different dash-offset defaults in WPF vs SVG, our developer will check.
