Normal Topic Custom Resource and Item classes (Read 36 times)
Raeees
Jan 31st, 2025 at 2:22pm
When using custom made classes like
Code (Java)
public class CustomResource  extends Resource
or
Code (Java)
public class CustomItem extends Item
do all the references from calendar point to the custom class objects?
Lets say for exampe i use
Code (Java)
calendar.getResources();
This line of code will return a list of ''ResourceList<Resource>'' and not ''ResourceList<CustomResource>'' or ''ResourceList<? extends Resource>''. issue with this is that i cant acces some of the new elements i add in my custom class. there are more instances of this ''small'' issue like with CustomItem Object but this is the first example to come to my mind.
Any insights in this issue will be appreciated.
Cordially.
Online
Re: Custom Resource and Item classes
Reply #1 - Feb 3rd, 2025 at 9:19am
I don't think the control limits you to a single type of custom resources in the collection, you could add instances of other Resource -derived classes. So if you need to access your custom properties, you'd have to use instanceof and downcasting. If you'll be using a single type of custom resource, you could add a helper method returning the proper type to do the typecasting just from one place.
