Normal Topic Problems with barcode label heigt (Read 17 times)
Alvaro68
Yesterday at 6:30pm
I am unable to adjust the height of a Code128 barcode to less than 26mm; I need the height to be 13mm and if I adjust it to that height it does not display or print.
I am able to make height 13mm using point but if I use milimiters it just does not work.
Thanks in advance
Re: Problems with barcode label heigt
Reply #1 - Today at 7:57am
26mm is about the nominal guard bars' height for UPC, maybe the control is applying it incorrectly for Code128 labels too. Our developer will investigate.
