Normal Topic Diagram.ModifierKeyActions are still used despite being marked as obsolete (Read 299 times)
nullable
Feb 20th, 2025 at 12:32pm
Hello Minfusion team,
Recently I found out that you are still using Diagram.ModifierKeyActions within your library (MoveNodesBehavior.cs, StartDraw method), but the property itself is marked as obsolete. Could you please remove this flag or use DiagramView.ModifierKeyActions in that part of code?
Re: Diagram.ModifierKeyActions are still used despite being marked as obsolete
Reply #1 - Feb 21st, 2025 at 9:46am
This build checks view's flags -
https://www.nuget.org/packages/MindFusion.Diagramming.Wpf/4.1.7-beta1
