Normal Topic Item look (Read 276 times)
Raeees
Item look
Mar 12th, 2025 at 6:36pm
using ResourceView, items come with a default look i can work with, inlcuding the gray bar on top (image inserted below). i can change its color using this line below but i would like to know how i disable it completly, like remove it from the item.
Code (Java)
calendar.getItemSettings().getStyle().setFillColor(Color.RED);
I would also like to know if its possible to disable Item selectedStyle. i wish to select items in the calendar but not modify their style.
Cordially
Re: Item look
Reply #1 - Mar 13th, 2025 at 7:13am
Try this:
ItemSettings itemSettings = calendar.getItemSettings();
itemSettings.setMoveBandSize(0);
itemSettings.setSelectedItemStyle(
    itemSettings.getStyle());
Raeees
Re: Item look
Reply #2 - Mar 13th, 2025 at 1:12pm
That did the job, thank you very much Smiley
