Normal Topic Item Vertical Move (Read 53 times)
Raeees
Item Vertical Move
Apr 2nd, 2025 at 6:20pm
In ResourceView, we are able to lock or disable moving items within the resources. However is there a way to only allow moving items accros resources, so basically only vertical dragging of items. The idea behind this is to keep same start and end date of the Item but change its Resource.
Cordially.
Re: Item Vertical Move
Reply #1 - Apr 3rd, 2025 at 11:02am
You could handle itemModifying event to keep original times:
calendar.addCalendarListener(
    new CalendarAdapter()
        @Override
        public void itemModifying(ItemModifyConfirmEvent e)
            e.setNewStartTime(e.getItem().getStartTime());
            e.setNewEndTime(e.getItem().getEndTime());
Raeees
Reply #2 - Apr 3rd, 2025 at 12:43pm
That did work, thank you
