Normal Topic Multiple images in one DiagramNode (Read 503 times)
Kuzya
Apr 14th, 2025 at 7:48am
Is it possible to add two images to one node? One image at the bottom right and another at the top right.
Re: Multiple images in one DiagramNode
Reply #1 - Apr 14th, 2025 at 7:56am
If you mean a ShapeNode, you could set its Image and ImageAlign properties to show one image. A second one could be custom-drawn by setting CustomDraw = Additional and handling DrawNode event, or by attaching a smaller locked node to the main one that only shows the image.
Alternatively, you can display multiple images inside TableNode, assigning them to cells' Image property, or CompositeNode that contains multiple ImageComponents.
Reply #2 - May 14th, 2025 at 10:28am
https://www.nuget.org/packages/MindFusion.Diagramming/7.1.0-beta1
This build supports multiple images using NodeLabels, using same API as in your JavaScript thread -
https://mindfusion.eu/Forum/YaBB.pl?num=1744808220/3#3
