Normal Topic Multiple images in one ShapeNode (Read 460 times)
Kuzya
Apr 16th, 2025 at 12:57pm
Is it possible to add two images to one ShapeNode? One image at the bottom right and another at the top right.
Kuzya
Re: Multiple images in one ShapeNode
Reply #1 - Apr 16th, 2025 at 2:09pm
Try code here -
https://mindfusion.eu/Forum/YaBB.pl?num=1488530760/4#4
Kuzya
Reply #2 - Apr 16th, 2025 at 2:51pm
Thank you
Reply #3 - May 1st, 2025 at 7:40am
This build adds image and imageLocation properties to ItemLabel, similar to the ones in ShapeNode:
https://mindfusion.eu/_beta/jsdiag47.zip
var node = diagram.factory.createShapeNode(10, 10, 40, 30);
node.shape = Shape.fromId("Rectangle");
var icon1 = node.addLabel();
icon1.setCornerPosition(1, 0, 0);
icon1.horizontalAlign = Alignment.Far;
icon1.verticalAlign = Alignment.Near;
icon1.imageLocation = "icon1.png";
icon1.margin = new Thickness(0, 0, 0, 0);
icon1.imageSize = new Size(10, 10);
var icon2 = node.addLabel();
icon2.setCornerPosition(2, 0, 0);
icon2.horizontalAlign = Alignment.Far;
icon2.verticalAlign = Alignment.Far;
icon2.imageLocation = "icon2.png";
icon2.margin = new Thickness(0, 0, 0, 0);
icon2.imageSize = new Size(10, 10);
Code above will be the official method of displaying multiple images per node going forward, instead of custom-drawing callbacks. The same properties should work for displaying images along a DiagramLink.
