Normal Topic Embedding fonts in an exported PDF (Read 43 times)
David Long
Jul 14th, 2025 at 10:52am
The PDF files that I export from PdfExporter do not show the fonts correctly in MS Edge, but look good in Acrobat. An internet search suggests that the fonts should be embedded in the PDF file for them to be shown correctly in Edge.  Is there an option or combination of options to do this?
DavidL
Re: Embedding fonts in an exported PDF
Reply #1 - Jul 14th, 2025 at 2:52pm
We might have done that deliberately, font files were usually copyrighted at the time we created PDF exporter... We'll have in mind an option for next release, in case you'd want to use it with free fonts (e.g. https://developers.google.com/fonts).
Reply #2 - Jul 15th, 2025 at 3:27pm
In our tests, Edge, Chrome and Firefox all display the fonts referenced from PDF as long as they are installed on the local system. Is there any specific font that's not working for you in that scenario?
David Long
Reply #3 - yesterday at 5:52pm
Just testing with Edge, our default font, Segoe UI, does not work, and neither does Arial. Acrobat seems to read both files OK.  The code we use to generate the files looks a bit like this...
                    var pdf = new PdfExporter();
                    try
                        pdf.AutoDetectEncoding = false;
                        pdf.DefaultEncoding = Encoding.Unicode;
                        pdf.Export(FlowChart, dlg.FileName);
                    catch (Exception ex)
                        ErrorBox(Resources.String_WriteFileFailed + ex.Message);
Both Arial and Segoe UI seemed to be installed locally.
DavidL
