Normal Topic Problem with styles (Read 4239 times)
Hunter
Problem with styles
Mar 28th, 2012 at 8:20am
Hello. I use the version 2.7.0.14366 of the library and find the problem. I use ActiPro WPFStudio DockingLayout and in their dockable windows I use Diagram objects and NodeListView object. When I enable applying styles to the native controls all objects from the NodeListView are disappearing. But when I change NodeListView to the standard WPF ListView I can't see this effect.
Re: Problem with styles
Reply #1 - Mar 28th, 2012 at 11:32am
Hi, What does the style you are applying look like?
Hunter
Reply #2 - Mar 28th, 2012 at 12:33pm
There are the standard themes such as Office 2007 Black, Office 2007 Blue, Classic, Luna and etc. I think when I allow to use themes for native controls it tries to apply these themes for the NodeListView inside the DockWindow and after that I don't see the elements inside NodeListView
Reply #3 - Mar 29th, 2012 at 7:53am
I don't have these controls, but changing the standard themes at the application level does not hide the NodeListView in my test app, so I suppose ActiPro's themes go too deep and replace the NodeListView's generic item template. You might try setting the generic template as an explicit ItemTemplate property value, so that it does not inherit the template from the parent control:
<diag:NodeListView Name="nodeListView" Width="300">
	<diag:NodeListView.ItemTemplate>
		<DataTemplate>
			<StackPanel Orientation='Horizontal' >
				<Border BorderThickness='3'>
					<ContentPresenter Content='{Binding}'/>
				</Border>
				<TextBlock Text='{Binding Path=(diag:NodeListView.Label)}'
						   VerticalAlignment='Center'
						   TextAlignment='Center'/>
			</StackPanel>
		</DataTemplate>
	</diag:NodeListView.ItemTemplate>
	<diag:ShapeNode Text="node1" Bounds="0,0,20,30" Shape="Decision" diag:NodeListView.Label="test label" />
	<diag:ShapeNode Text="node2" Bounds="0,0,20,30" Shape="Ellipse" diag:NodeListView.Label="test2" />
</diag:NodeListView>
Joel D.
Reply #4 - Apr 20th, 2017 at 5:57am
I think I was having the same problem, but it was the ItemContainerStyle that I had to explicitly set on the NodeListView to get the items to actually show up in the list.
Reply #5 - Apr 20th, 2017 at 10:30am
Are you using ActiPro themes too?
Joel D.
Reply #6 - Apr 21st, 2017 at 3:41am
No, not ActiPro themes.  I'm using ExpressionDark, which I think I got from Microsoft's WPF Toolkit.
