Normal Topic Create Customized sized canvas layout (Read 3076 times)
kelum
Apr 20th, 2017 at 5:57am
I have a requirement to Customized sized canvas layout using dashboard tool bar,
if I explain this further
1. Initially load the Main Window
2 .Once click a button I can provide Height and Width of the canvas
3. Then that canvas generate inside main window
Kelum
Re: Create Customized sized canvas layout
Reply #1 - Apr 20th, 2017 at 7:50am
Set diagram.Bounds = new Rect(0, 0, width, height) after you have the width and height.
kelum
Reply #2 - Apr 20th, 2017 at 12:04pm
I have following user control, this is where mind-fusion canvas included
    public partial class LayoutWindow : UserControl
     inside this user control I have a button to open an another window call `PopUp`.
So I'm trying to update `LayoutWindow` UserControl `diagram.Bounds` property(which is canvas size), once above `OkButton_Click` click inside `PopUp` Window
public partial class PopUp : Window
	    private void OkButton_Click(object sender, RoutedEventArgs e)
              LayoutWindow lw= new LayoutWindow();
              lw.InitializeComponent();
              lw.diagram.Bounds = new Rect(0, 0, 400, 400);
              Close();
     but in this way it's not updating the canvas, how can I do this properly
Reply #3 - Apr 20th, 2017 at 12:21pm
This code shows you assigning fixed 400x400 size to the diagram, and not one entered by users.
kelum
Reply #4 - Apr 20th, 2017 at 2:18pm
Nope, actually 'Popup' window contains that height width, I'm getting that values and bind here, for the simplicity I explain that way.
kelum
Reply #5 - Apr 21st, 2017 at 3:17am
thanks I sorted out it my self
