Normal Topic Stretch diagram (Read 3167 times)
Hunter
Stretch diagram
Jul 20th, 2010 at 8:30am
Hello. I have the problem with stretch. I have the user control with Diagram object. And all alignment properties are Stretch. But when I ZoomOut diagram it doesn't stay stretched. I looks like it's alignment properies are Center, Center. I can't understand why? Can I send you the sample project for take and advice or I need to post code their. Initializing of the user control are in the xaml and in the code. That's why it may be too large...
Re: Stretch diagram
Reply #1 - Jul 20th, 2010 at 10:21am
The diagram never stretches automatically to fill its container if that's what you are asking. It is always as big as its Bounds value multiplied by the zoom level. You can handle the container's SizeChanged event and set larger diagram.Bounds value from the handler to enlarge the diagram area if necessary.
Hunter
Re: Stretch diagram
Reply #2 - Jul 20th, 2010 at 10:32am
Yes. For this purpose I use the following code:
	  private void OnRuler_SizeChanged(object sender, SizeChangedEventArgs e)
		if (m_Diagram.Bounds.Width < e.NewSize.Width)
		    Rect newBounds = new Rect(m_Diagram.Bounds.X, m_Diagram.Bounds.Y,
			  e.NewSize.Width, m_Diagram.Bounds.Height);
		    m_Diagram.Bounds = newBounds;
But I have the ZoomIn and ZoomOut buttons on the toolbar. And when I press ZoomOut the diagram area decreases but the ruler size is constant... An I need to fill all area by the diagram
Re: Stretch diagram
Reply #3 - Jul 20th, 2010 at 10:55am
Move this code to a separate method and call the method from both container.SizeChanged and Diagram.ZoomFactorChanged handlers. Additionally, multiply the width and height by 100 / ZoomFactor.
Hunter
Re: Stretch diagram
Reply #4 - Jul 20th, 2010 at 11:11am
But Diagram.ZoomFactorChanged doens't have the NewSize property in the event arguments...
I wrote the following:
	  private void OnDiagram_ZoomFactorChanged(object sender, EventArgs e)
		    m_Diagram.Bounds.Width * 100 / m_Diagram.ZoomFactor,
		    m_Diagram.Bounds.Height * 100 / m_Diagram.ZoomFactor);
In the first look it works
Re: Stretch diagram
Reply #5 - Jul 20th, 2010 at 12:34pm
You could use the container's ActualWidth and ActualHeight properties to get its size when not in OnSizeChanged.
Hunter
Re: Stretch diagram
Reply #6 - Jul 20th, 2010 at 12:44pm
Is it correct?
		    m_Ruler.ActualWidth * 100 / m_Diagram.ZoomFactor,
		    m_Ruler.ActualHeight * 100 / m_Diagram.ZoomFactor);
#if false
#endif
Re: Stretch diagram
Reply #7 - Jul 21st, 2010 at 1:54pm
It looks ok. You might also make it Math.Min(current width, new width) and same for height, so that the diagram does not get smaller then its initial size when zooming in. Otherwise some nodes might remain out of the current viewport and you would not be able to scroll to them.
