Normal Topic drag'n drop from Listbox into a Mindfusion calendar in Silverlight app (Read 9525 times)
SLUser
Dec 7th, 2012 at 1:59pm
Is it possible to perform a drag from a listbox item into a calendar control ? The listbox is surrounded with the ListBoxDragDropTarget (= SLtoolkit) and the drag operation starts, but in the calendar I do not seem to receive any drag enter, drag over or drop events.
However, if I drag a file from windows explorer over the calendar, the events do get fired.
Thanks !
Re: drag'n drop from Listbox into a Mindfusion calendar in Silverlight app
Reply #1 - Dec 7th, 2012 at 4:52pm
I think you need to create a DragDropTarget implementation for the Calendar class in order to enable Silverlight toolkit drag&drop for it. This might be hard because the toolkit drag&drop appears to be designed specifically for ItemsControl as a target, and Calendar does not inherit from ItemsControl.
I will look for a solution and get back to you.
SLUser
Reply #2 - Dec 8th, 2012 at 6:09pm
But the calendar control does support drag and drop (works from windows explorer), isn't there a way to initiate such a drag action from with silverlight itself (eg. from the listbox) ?
I am trying to list up resources (people) next to the calendar (eg. in a listbox), and the user must be able to drag a person onto the calender for which then an appointment is created. Perhaps there is an easier way to achieve this ?
Thanks again.
Reply #3 - Dec 10th, 2012 at 8:36am
Check the attached sample. It implements a very simple drag&drop between a ListBox and the Calendar without using the Silverlight toolkit.
I hope it helps.
SLUser
Reply #4 - Dec 14th, 2012 at 8:20am
This seems to work great. Thanks !
FYI: I had also found an alternative way by implementig the IAcceptDrop interface in the control containing the calendar.
But now I find this solution also interesting. I'm not sure yet which one I will use.
