Normal Topic Recurring Appointment. How to make an exception ? (Read 4429 times)
SLUser
Dec 27th, 2012 at 8:06pm
With recurring appointments, it is possible to create exceptions by moving a specific appointment to another date. However it is also possible to create an exception with another property (lets say I derived from appointment and added a string property 'ExtraInfo' which is only filled in for a few specific items of my recurring appointment.
Re: Recurring Appointment. How to make an exception ?
Reply #1 - Dec 28th, 2012 at 7:31am
If you need to create exceptions programmatically, simply set the respective property (StartTime, EndTime, and so on) of the item occurrence to its new value and this should automatically create an exception. For custom properties, you need to call Recurrence.MarkException passing a reference to the item.
To get a reference to the occurrence (other than by handling an event), call the GenerateItems method of the item's Recurrence instance.
SLUser
Reply #2 - Dec 28th, 2012 at 9:39pm
Works fine ! Thanks.
