Normal Topic Evaluating Diagramming product - some questions (Read 7035 times)
Lothar Behrens
Feb 13th, 2014 at 8:08am
I am a DevExpress user and like to focus my questions around integrating the two libraries.
1.) I have seen a IScrollBarProvider interface that let me use my DevExpress scrollbars for skinning reasons. Does anyone have yet developed an implementation based on that interface, I could benefit from (not to reinvent)?
2.) Is there anyhow a databinding possible to show simultanuously, say, the node names in a grid?
(Nevron has at least data import capabilities, but I have seen a posting here with a very simple starting point for Entity Framework)
3.) Are there any DevExpress users out there to share some whitepapers of their products using Mindfusion Diagramming (product descriptions on your web pages are good enough)?
I am tending to use Mindfusion for one reason: IScrollBarProvider for skinning purposes.
Please impress me with more possibilities Smiley
Lothar Behrens
Re: Evaluating Diagramming product - some questions
Reply #1 - Feb 13th, 2014 at 9:31am
Here is a DevExpress implementation:
using DevExpress.XtraEditors;
using MindFusion.Diagramming.WinForms;
namespace ScrollBarProviderWrapper
 public class DevExpressScrollBarProvider : IScrollBarProvider
  #region IScrollBarProvider Members
  public void AddScrollEventHandler(System.Windows.Forms.Control scrollBar, System.Windows.Forms.ScrollEventHandler handler)
   ScrollBar(scrollBar).Scroll += handler;
  public System.Windows.Forms.Control CreateHorizontalScrollBar()
   return new HScrollBar();
  public System.Windows.Forms.Control CreateVerticalScrollBar()
   return new VScrollBar();
  public float GetLargeChange(System.Windows.Forms.Control scrollBar)
   return (float)ScrollBar(scrollBar).LargeChange;
  public float GetMaximum(System.Windows.Forms.Control scrollBar)
   return (float)ScrollBar(scrollBar).Maximum;
  public float GetMinimum(System.Windows.Forms.Control scrollBar)
   return (float)ScrollBar(scrollBar).Minimum;
  public float GetValue(System.Windows.Forms.Control scrollBar)
   return (float)ScrollBar(scrollBar).Value;
  public void SetLargeChange(System.Windows.Forms.Control scrollBar, float value)
   ScrollBar(scrollBar).LargeChange = (int)value;
  public void SetMaximum(System.Windows.Forms.Control scrollBar, float value)
   ScrollBar(scrollBar).Maximum = (int)value;
  public void SetMinimum(System.Windows.Forms.Control scrollBar, float value)
   ScrollBar(scrollBar).Minimum = (int)value;
  public void SetValue(System.Windows.Forms.Control scrollBar, float value)
   ScrollBar(scrollBar).Value = (int)value;
  #endregion
 public partial class Form1 : Form
  public Form1()
   InitializeComponent();
   diagramView1.ScrollBarProvider = new DevExpressScrollBarProvider();
I'm pretty sure we added this interface for a customer that used DevExpress too, but that was a long time ago and I can't point you to their website.
There is no built-in databinding support. You could probably create a small adapter that implements INotifyCollectionChanged and raises the interface events in response to diagram's ItemAdded, ItemRemoved, TextEdited events to make the grid update dynamically. Or perhaps just set diagram.Nodes as grid's data source and use some grid update method to refresh the data from same events.
Lothar Behrens
Reply #2 - Feb 13th, 2014 at 1:01pm
While waiting, I have made a decision by stomage and I am happy. I am a owner now Smiley
I'll take your provider implementation as it seems to be clear what will happen where.
Thank you very much Smiley
Lothar
Lothar Behrens
Reply #3 - Feb 13th, 2014 at 2:08pm
Just a small correction. The code should actually look like this:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Windows.Forms;
namespace Wrappers
    class ScrollBarProvider : IScrollBarProvider
        public void AddScrollEventHandler(Control scrollBar, ScrollEventHandler handler)
            ((ScrollBarBase)scrollBar).Scroll += handler;
        public Control CreateHorizontalScrollBar()
            return new DevExpress.XtraEditors.HScrollBar();
        public Control CreateVerticalScrollBar()
            return new DevExpress.XtraEditors.VScrollBar();
        public float GetLargeChange(Control scrollBar)
            return (float)((ScrollBarBase)scrollBar).LargeChange;
        public float GetMaximum(Control scrollBar)
            return (float)((ScrollBarBase)scrollBar).Maximum;
        public float GetMinimum(Control scrollBar)
            return (float)((ScrollBarBase)scrollBar).Minimum;
        public float GetValue(Control scrollBar)
            return (float)((ScrollBarBase)scrollBar).Value;
        public void SetLargeChange(Control scrollBar, float value)
            ((ScrollBarBase)scrollBar).LargeChange = (int)value;
        public void SetMaximum(Control scrollBar, float value)
            ((ScrollBarBase)scrollBar).Maximum = (int)value;
        public void SetMinimum(Control scrollBar, float value)
            ((ScrollBarBase)scrollBar).Minimum = (int)value;
        public void SetValue(Control scrollBar, float value)
            ((ScrollBarBase)scrollBar).Value = (int)value;
Actually this code works.
Reply #4 - Feb 13th, 2014 at 2:18pm
Ours worked too, but I forgot to copy this method, sorry:
 private ScrollBarBase ScrollBar(System.Windows.Forms.Control scrollBar)
   return (ScrollBarBase)scrollBar;
LanDocs
Reply #5 - Aug 7th, 2014 at 1:11pm
Hi!
I use your code for DevExpress implementation:
Stoyo wrote on Feb 13th, 2014 at 9:31am:
  #endregion
  public Form1()
and got strange scrollbars behavior - DevExpress scrollbars doesn't work same as MindFusion scrollbars. See my example in attachment, please. In example left DiagramView use DevExpress scrollbars and right DiagramView use MindFusion scrollbars, ZoomTrackBar change zoom value for both DiagramViews. How make DevExpress scrollbars to work same as MindFusion scrollbars?
ScrollTestApp.zip (Attachment deleted)
LanDocs
Reply #6 - Aug 7th, 2014 at 1:24pm
We have the same problem with scrollbars on FCNet 6.1.3 and DevExpress 14.1. Is where a way to make them working as native MindFusion's scrollbars?
Reply #7 - Aug 7th, 2014 at 2:20pm
If you mean the scrollbars not hiding when zooming out, it seems to happen because the DX scrollbars' GetLargeChange method starts returning incorrect values when we hide them first time, and they get shown again. Instead of delegating from GetLargeChange to them, return a value stored from last set:
private float largeChange;
   return largeChange;
   largeChange = (int)value;
Then it works correctly for us using DX13.
LanDocs
Reply #8 - Aug 8th, 2014 at 8:10am
Thank you very much! It works for us too.
