Normal Topic RoundRectangle outline (Read 2134 times)
CanadaProgrammer
Feb 25th, 2014 at 12:14am
I defined 2 shapes (actually it should be outline of a shape), like below:
MDShapes.RoundRect = new Shape(
     new ElementTemplate[]
           new RoundRectangleTemplate(0, 0, 100, 100, 8)
     }, FillMode.Winding);
MDShapes.ActivityAccept = new Shape(
           new LineTemplate(0, 0, 100, 0),
           new LineTemplate(100, 0, 100, 100),
           new LineTemplate(100, 100, 0, 100),
           new LineTemplate(0, 100, 8, 50),
           new LineTemplate(8, 50, 0, 0)
The first one is round rectangle. then i defined 2 node, assign RoundRect to
one node, and assign ActivityAccept to another when. Then save diagram to
string and load the string to diagram again. round recttangle changed to rectangle
and ActivityAccept is still same.
if I assign Shapes.RoundRect to node, then it can be same shape when reload
string to diagram. That's why ? how to resolve it?
Thanks a lot.
Re: RoundRectangle outline
Reply #1 - Feb 25th, 2014 at 11:44am
Shapes are saved only by their string identifier, you will have to specify it as last argument of the Shape constructor:
MDShapes.ActivityAccept = new Shape(..., "ActivityAccept");
You must run that shape initialization code when your application starts to make sure there are shapes associated with the identifiers before loading a diagram. Alternatively, save the custom shapes in a shape library file and load it upon start-up.
CanadaProgrammer
Reply #2 - Feb 25th, 2014 at 4:24pm
Thanks, it can work well.
