Normal Topic XAxis Label (Read 5768 times)
kmck
XAxis Label
Jun 11th, 2014 at 8:58am
I have automatic code which get the following datat source : Y data - 4
X data - 1.95
And generate the following numbers for the chart
this.lineChart.XAxisSettings.MinValue = 1.56;
this.lineChart.XAxisSettings.MaxValue = 2.34;
this.lineChart.XAxisSettings.AxisDelta = 0.195;
this.lineChart.XAxisSettings.NumberCustomFormat = "0.#";
this.lineChart.XAxisSettings.NumberFormat = MindFusion.Charting.NumberFormat.Custom;
this.lineChart.XAxisSettings.LabelType = MindFusion.Charting.AxisLabelType.AutoScale;
I got the attached chart
You can see that the 1.95 value look on the chart as 2
I found that this happen when the min value has more digits after the dot then defined NumberCustomFormat
I think this is a bug.
Can you please advice
Attched is the test application I created for that case
Kobi
MindFusionTests.rar (Attachment deleted)
Re: XAxis Label
Reply #1 - Jun 11th, 2014 at 10:22am
The actual position is 1.95, but the label is rounded to 2 by Float.ToString("0.#"). Set NumberCustomFormat = "0.##" to see 1.95.
kmck
Re: XAxis Label
Reply #2 - Jun 12th, 2014 at 6:44am
I would expect that if I round the label the position will be update as well otherwise it may confuse
According to what you say I am not supposed to round the label which will always cuase to this issue
Re: XAxis Label
Reply #3 - Jun 12th, 2014 at 7:17am
Automatic labels can be drawn only at regular intervals at this time. You will have to match NumberFormat to AxisDelta's numeric precision to avoid rounding offsets, or set such AxisDelta that will fit the label precision you want to show, i.e. 0.2 instead of 0.195.
