Normal Topic drop wire to delete it (Read 2098 times)
ChangMH
Jul 5th, 2014 at 12:35pm
My requirement is to delete wire by moving its end away from node and dropping it. If I do that now the wire returns to where it was. Thanks for any advice.
Re: drop wire to delete it
Reply #1 - Jul 7th, 2014 at 5:31am
You could set AllowUnconnectedLinks = true to let users drag the link end to an empty location of the diagram, and then delete the link from LinkModified handler when it isn't connected to a node:
private void OnLinkModified(object sender, LinkEventArgs e)
	if (!e.Link.IsConnected)
		diagram.Links.Remove(e.Link);
ChangMH
Reply #2 - Jul 9th, 2014 at 6:41am
It works. Is it possible to remove e.Link only if its end is 20 pixels or more away from node, and it stays connected if it is close than 20 pixels?
Reply #3 - Jul 9th, 2014 at 1:48pm
Add a LinkModifying handler and set e.Cancel = true if you detect the mouse pointer is still close to the node:
private void OnLinkModifying(object sender, LinkValidationEventArgs e)
	if (e.AdjustmentHandle == 0)
		var dist = Utilities.Distance(
			e.MousePosition,
			e.Link.Origin.GetNearestBorderPoint(e.MousePosition));
		if (dist < 20)
			e.Cancel = true;
	if (e.AdjustmentHandle == e.Link.ControlPoints.Count - 1)
			e.MousePosition,
			e.Link.Destination.GetNearestBorderPoint(e.MousePosition));
		if (dist < 20)
			e.Cancel = true;
