Normal Topic problem with anchor. (Read 1861 times)
ayushneema
Oct 9th, 2009 at 11:05am
Hi
i have created diagram that contain nodes. i am showing anchor on node but on the initialization i am setting diagram.ShowAnchors = ShowAnchors.Never.
I have a boolean variable which is checked in diagram_mousemove event to show anchor, i.e if flag is true, show anchor on node and i am changing the flag's value on button click.
But my problem is that when i set the flag's value to "false" then for the first node(when i enter a mouse on any node) it show anchor.
I am sending the sample application. please reproduce the issue using following steps:
1. run the applicaton. initially flag is false so when you move mouse on node there will be no anchor.
2. click on button "Set Flag". a message box will be displayed with the value of flag.
3. Move mouse on node, now for the first node it will show anchor.
Ayush Neema
Re: problem with anchor.
Reply #1 - Oct 9th, 2009 at 7:04pm
You can toggle the ShowAnchors value in the same method that sets the boolean variable. That way the values will be in sync all the time; now they are not and you get node_MouseMove raised after the anchor point has already been displayed.
ayushneema
Reply #2 - Oct 10th, 2009 at 9:18am
Hi Stoyan
Thanks for quick replay.
It is working as expected.
